Suspension & Brakes Theory, alignment, spring rates....
Spoon Twin Block Caliper.. Clicks
Old Nov 6, 2009 | 03:30 PM
teamm_AP1's Avatar
Default Spoon Twin Block Caliper.. Clicks
I recently installed my Spoon calipers and I need some help. The calipers do not have clips to keep the pads seated.
From that, the pads click and make the noise every time I go in reverse.
Please let me know what you have done to solve this issue.... Thanks in advance.
Old Nov 6, 2009 | 06:33 PM
teamm_AP1's Avatar
Default Re: Spoon Twin Block Caliper.. Clicks
Well I think I've found the cure for this noise... I contacted AJ-racing and research on the net. The common fix for this noise is to bend the clips on the inside of the caliper so it acts as a spring, thus eliminating the play within... I will update with pictures when I fix this later.
Old Nov 9, 2009 | 08:08 AM
No_Fear's Avatar
i removed from my stock calipers this :
number8 in the diagram
and installed them in the spoon ,then the noise stoped
Old Nov 9, 2009 | 07:07 PM
teamm_AP1's Avatar
^^ hey thanks for contributing to this thread. I actually found a thread from another forum and a guy used the same pad spring as you. I ordered two pad springs (#8 from the pic you posted) the other night.
Update on adjusting tabs: I adjusted the rear tabs on the calipers and the noise is minimized a while lot. I hope to eliminate the noise for good when the spring clips arrive.
Old Mar 2, 2010 | 03:07 AM
ee8rex's Avatar
New User
I'm having the same clicking noise as well.
For the stock spring should I the one on front or rear caliper?
The red arrow pointing pic looks like DC2/EK9 front caliper but the second pic looks like rear caliper with the cross pattern the piston??
Old Mar 3, 2010 | 09:41 AM
No_Fear's Avatar
i used the front of the EK9 brakes.(ek4 have smaller braked might not fit)
Kavehman
Mar 16, 2007 06:15 PM
jinn
Jul 3, 2006 08:12 AM
Hollywoood
Aug 17, 2004 02:44 PM
an2ny888
Dec 12, 2003 05:50 AM
geometro
Aug 19, 2001 01:10 PM
