Piston design
Can anyone explain how the design of a piston effects the combustion process. I was reading the "how to build a reliable lsvtec/b20vtec" and saw this.
Then this reply,
Just wanted some insite on piston design. Which design is more efficient?
Your so outta your ball park its unreal.
They aren't in anyway identical to p30's. P30's are used as a good solution to people wanna bump the compression up, and have a good flame and piston weight
CTR pistons are called slugs for a reason. They are the heaviest piston for b series.. and the dome is entirely too fat and big, it spreads the flame too thin and doesn't allow for the correct combustion process.. other pistons come to a point, you'll notice on ctr's at the top of the dome is almost flat for 3/8ths of a inch which spreads the flame too thin..
ctrs are ****en garbage. They belong in nothing but a b16.
yeah i been doing this for well over 10 years starting at place racing back in the day and moving to golden eagle so i do know what I'm talking about from years of experience. yes it spreads the flame just like all high comp pistons so are you going to tell me that a flat top piston witch has the best flame travel will make more power then a max compression piston? if so you better go tell all the all motor guys there doing it wrong. my info is fact was proven on a dyno if i still had the sheets i would post them for you to see but every motor i have ever seen using the ctr piston makes way more power then using the p30 pistons. i will however agree that ctrs in a lsvtec are a little high compression for Daily driven car and if not going to get it properly tuned then you should run the itr pistons but with proper build and tune you should be fine
It's a generally accepted principle that a flatter top piston is better for flame travel, tends to be more resistant to detonation, you can run a little more timing all while using pump gas.
If built and tuned well, it may be possible to make more power on a domed piston, I wouldn't know as I haven't tested or experienced it myself. If I was building a motor, I would personally stay away from the CTR pistons but ultimately the choice will be yours.
check out cbr, gsxr, crf, yfz pistons. any of the pistons in rockets or 4stroke MX bikes. all engines making exceptional power per cid
here is some F1 stuff. check out the piston with the signatures on the top.
https://www.team-bhp.com/forum/techn...gine-pics.html
make your own conclusion about domes.
Those pistons look like they're probably mirror's of their respective combustion chambers. they aren't the ridiculous / \ shaped domes. There's surely a point where combustion effeciency loses to compression or you wouldn't see them out there. I guess it would be easy/ideal if a given motor made adequate compression with flat top pistons.
the problem arises then the chamber is too large for the desired compression. the easiest thing to do is make the piston to take up the space.
it's all a packaging deal on the engines we are dealing with. on production stuff the intake manifold cant stick up out of the hood and the engine cant be lowered any more to keep the IM under the hood so the ports are shallow in the head. then the valve gets angled more and the chamber gets more of a peak in it.
Those flat spots that seem to mirror the combustion chamber are called quench zones. They force the fuel mixture toward the spark plug creating a more complete burn. In doing this they also keep those flat areas cooler and reduce detonation in a high compression chamber. Honestly I never understood the exaggerated /\ on most of the B series HC pistons. But now I see that it is because of poor OEM combustion chamber design.
The aftermarket only feeds the demand for people wanting higher compression engines. In order to do this they create drastic dome pistons to fill the large combustion chambers. It's much easier to do that than it would be to change the geometry of the combustion chamber.
Sorry, I could've worded it better. My point is that you can achieve 11-12:1 compression with flat top pistons in the Accord engines (possibly others as well), which is ideal. Why are the higher performance motors designed to use heavy domed slugs? Isn't that a design flaw?
Can someone explain to me what this guy is trying to say for clarification. So a flat piston is more efficient, but he says the ctr piston is to flat "which spreads the flame to thin".
Most higher performance motors don't use "heavy domed slugs", it's only the B16b that uses them. It's not so much a design flaw as it's a design "compromise". In those situations a part is sometimes selected that will do the job but not necessarily in the best possible mannor to achieve a certain goal in a certain way. It's possible that Honda wanted a simple solution to achieving a certain compression ratio in the b16b without having to change anything else like rod length or stroke etc. In that sense, many aftermarket companies do the same thing by designing large domed pistons to gain a certain level of compression to perhaps run a certain type of cam or fuel. It is better to redesign the combustion chamber, alter rod length or stroke and come up with a more efficient design but this obviously costs more money and isn't always possible. So the domed piston is the cheapest "compromise".
A domed head allows for larger valves, with allows better high RPM breathing, which is where performance oriented Honda engines make their power, which is why performance Honda engines have domed heads and pistons.
with the design of the head you can pretty much stuff the chamber full of piston and get away with it. other engines, not so much.
the theory is sound, but in practice it doesn't make much difference.
I have a mahle Toyota F1 piston.. im not sure of the CR of those engines but the piston does not have a dome per say, but you can tell from the design of the piston that they basically fill the chamber with the piston. the valves are early parallel which further allows for this design.
the old "dome hurts efficiency" thing holds very true for engines with crappy 2 valve heads, on a good 4 valve chamber its not really that big of an issue.
Correct. Ya he's more or less saying that the height of the dome on those pistons act like a wall, disrupting the flame travel across the top of the piston.
Thank you sir, makes sense!
ShawnR
Feb 2, 2015 04:32 AM
