88 crx harness
ok question i have a 90 crx hf and i found this 88 crx hf harness i know one plug is to big by the injector box is that the only wire plug u have to change... for the harness to work on my 90 crx hf..
88 and 90 HF engine harnesses should be the same - are you sure that the one with the larger plug isn't a DX harness? DX has a round 14-pin connector at driver's side - HF has round 8-wire connector
