hid projector help
So I have a 2003 acura tl, I was wondering where can i get projectors for my tl. I dont think they make them so if they do please link. If they dont then can you tell what other models projectors will fit. Do tsx projectors fit?
yea i think you got the last body year before switching from reflector hid to projector hid. There is no specific projector to use, other than anything that accepts a D2S bulb. TSX will fit, even a TL will fit. you have plenty of room in there. since you have separate hi beams, id say chances are you could even fit a lexus projector from the LS line in there, which are pretty much considered the best lo beam projector on the market
sorry for the confusion. im referring to doing a retrofit of the projectors into the existing lamps. As far as I know, nobody makes a direct replacement projected hid system for the 03, so if you want projectors, a retrofit is pretty much your only option
unless you are having lighting issues, the expense would not be worth it. It's gonna cost you a lot of money to change over to a projector setup. I have an 02 CL-S and the HID setup is great. I never have to sue my highbeams (highbeam lights are original on the car)
seabassrsx19
Mar 11, 2008 09:24 AM
van_ap1
Nov 1, 2001 12:02 AM
