Civic/Integra Turbo Parts. B18B, B16
Old Nov 5, 2009 | 06:24 PM
Hybrid96EK's Avatar
Default Civic/Integra Turbo Parts. B18B, B16
I am parting out the rest of the parts left over from my Edelbrock turbo kit. The original manifold, turbo and downpipe are already gone. Here is what I have left!
Intercooler. These are high quality Spearco intercoolers. Stamped "Edelbrock". The upper mount bracket is broken off. Will include the bracket, you can reweld if you like. New these retail for $669. I am asking only $200.
Charge pipes. These pipes fit perfect on EK chassis. Didn't even need to cut the bumper to clear! I modified two of the pipes to work with stock intake manifold instead of the Edelbrock intake manifold. Includes the TIAL BOV. Very high quality BOV, excellent sound. Also includes all new high quality silicone couplers and T bolt clamps. I paid $50 for the clamps alone! A steal at $200 for the complete pipe set, BOV, couplers, and clamps!
Edelbrock sandwhich oil filter adapter. Supplies clean filtered oil to your turbo. Can also be used for Ls/Vtec, oil pressure gauges, etc! $70 with the stainless steel supply line and ALL FITTINGS needed!
Omnipower 3 bar MAP sensor. This will allow you to read up to 28psi of boost. This looks exactly like the OEM unit except its orange. Plug is the same. WILL REQUIRE THE USE OF AFTERMARKET ENGINE MANAGEMENT SYSTEM. WILL NOT WORK WITH STOCK ECU. New is $130. Asking $70.
RevHard A/C compatible B series turbo manifold. 38mm wastegate opening. Used, good condition. I cleaned it up, painted it with VHT high temp flat black and never ran it. Ready for you to run, looks great! $100
1997 B18B1 Integra LS Block. Vin tag in tact, not stolen! Block is standard bore, excellent shape. Washed, honed, ready to assemble. Asking $50 for the block only. I DO have the crank, pistons, rods, oil pan, rear main, and oil pump. $100 complete.
1997 B18B1 Integra LS crankshaft. Journals in great shape. Ready to use, $70
B18B1 cylinder head. Has valves, springs, retainers, rockers, cams, cam caps, valve cover. $50.
Stock JDM B16A SIRII intake manifold. Sold as you see it. $20
I will consider trades for the following items ONLY:
B16 hydro transmission
Passenger side OEM 99-00 Civic headlight
B series 4-1 header
CTR/ITR/Stage 1 B series vtec cams
99-00 Civic SI cold air intake
All prices are for items PICKED UP LOCALLY. Shipping will be additional, paypal accounts need to add 4% to cover fees. I am in the Marysville/Yuba City area. Occasionally I am available in the Roseville, CA area as well.
Old Nov 5, 2009 | 09:10 PM
NegroEk's Avatar
Default Re: Civic/Integra Turbo Parts. B18B, B16
good seller!
9three4drintegra
Mar 27, 2013 06:01 AM
crazygringo90
Nov 2, 2009 11:55 AM
Hybrid96EK
Oct 28, 2009 05:50 AM
nuckingfuts
Jul 9, 2007 10:00 AM
