2001 gsr 4dr sedan k24a2 arc cwest superstreet jan 09 feature cr
http://www.superstreetonline.com/fea...gsr/index.html
I BOUGHT THIS BRAND NEW IN 2001 OFF THE LOT. CLEAN TITLE. Never in a accident.motor has 2500 miles. this was a trainwreck motor from nikos. I dont ever drive this car. Its ready to be tracked. The fuel system alone was 2500. the wheels were 6000. . Will part it out any way you want. Wwant to trade for a gs300/s2000
2001 Acura Integra GSR - Keep It On The DL
Under The Hood 2.4L naturally-aspirated K24A2; Hasport EGK1 mounts; DTR 2.4L large tube header; Custom 3" exhaust; Hybrid Racing PNP K20 engine harness; Yeeserious plumbed and shaved RBC manifold, shaved valve cover; Karcepts throttle body adapter; Aeroquip starlite hose; Team 2to custom-shaved engine bay, wire tuck, brake line tuck; Jiffytite quick disconnect fittings; ARC Skyline oil cooler; Mugen oil filter; Fuel lab fuel filter and fuel pressure regulator; AEM fuel rail; ; FEEL'S master cylinder brace; Beatrush cooling plate; Samco radiator hoses; Visteon radiator; Sard oil cap; Marshall fuel gauge; Alloy Racing catch can; Vision test pipe; Walbro 255 fuel pump; Spoon Sports radiator stay; Custom intake with AEM bypass; K&N air filter and catch can breather; NGK spark plugs
Drivetrain Exedy Stage 2 clutch; Karcepts shift mount kit
Brains Hasport/Hondata K-Pro
Stiff Stuff Function Form Type 2 coilovers; Function7 rear lower control arms; ITR front sway bar; Comptech rear sway/tie bar combo; Skunk 2 camber kit front and rear; Summit 4pt rear strut bar; JDM ITR 4X114.3 suspension conversion; FullRace traction bar (track)
Stoppers ITR front calipers and rotors; Hawk HP brake pads; ARP extended wheel studs
Rollers HRE 540R 17X9 front 17X8 rear wrapped in Falken Azenis 215/40/17 front 205/40/17 rear (street); ; Project Kics R40 lug nuts
Outside Audi TT Brilliant Red paint; C-West front lip, side skirts, carbon-fiber hood; ARC front splitters; Z spec carbon-fiber front canards; JDM front end conversion; J's Racing fender flares; JDM HOP window visors; Mugen trunk latches; VIS carbon-fiber trunk; Custom rear diffuser w/side generators; Custom side mirrors; Shaved door moldings; Rear door handles all around (keyless); Moroso battery kill switch mounted in trunk; Remote battery terminals mounted in taillight, rear diffuser with vortex genrators
Inside Mugen door sill plates, shift ****, pedal set, DC5R dead pedal, ECU stay, , Personal steering wheel, bride zeta 2 driver seat no pass ; ; Custom suede door panels, head liner, pillar covers; Odyssey PC925 battery in trunk; Circuit Hero shifter; HOP personal box, clock delete, airbag delete, radio delete, armrest delete; ; Splash short steering hub;
