GSR Manual Cluster into an Ex-Auto '96 LS
I just bought an LS with an auto to manual swap and I want to change the cluster to match. GSR cluster since they are inexpensive and up the redline but want ot make sure I purchase a compatible cluster.
My research tells me I should be looking for a 94-97 GSR cluster for my 96 teg. Is this correct for a plug and play install?
I was told there is a difference in the top-end of the rev range on the cluster - DC2 has a higher rev limit than DC4. Is this true?
The 94-01 GSR cluster reads as high as 9,000RPM, the 94-01 LS, RS, GS, SE cluster reads as high as 8,000RPM.
To directly answer your question, all year/trim Integra clusters are compatable plug and play.
