what size tire for 15X7 +35 offset?
Old Nov 5, 2009 | 01:45 PM
n0rmaL's Avatar
Default what size tire for 15X7 +35 offset?
just got some enkei's 15X7 with a +35 plus offset. im putting them on a 92 prelude lowered about 2" with gc's/Tokico Illuminas. my question is whats the best tire size to get? and will i have to roll my fenders?
Old Nov 5, 2009 | 02:38 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: what size tire for 15X7 +35 offset?
If it's a base Prelude, 195/60-15. If it's a Prelude Si, 205/55-15.
Old Nov 5, 2009 | 02:39 PM
RSZero1's Avatar
Depends on what you are looking for, personally I like a meaty tire. You can run a 195/50/15, 205/50/15 OR if you have some decent fender clearance 225/45/15.
The 225's may require a fender roll, not sure on that one.
205's should be a safe bet if you are not planning to slam the car and actually enjoy driving it.
What he said is the CORRECT size. Mine are just suggestions based on previous exp.
Old Nov 5, 2009 | 02:44 PM
nsxtasy's Avatar
H-T Order of Merit
That's BAD ADVICE. Those tire sizes are MUCH TOO SMALL for a '92 Prelude, and are not the best sizes to use. Remember, tire sizes that work on Civics or Integras do not necessarily work on other cars. On a '92 Prelude, stick with 195/60-15 or 205/55-15.
Old Nov 5, 2009 | 02:54 PM
n0rmaL's Avatar
its a prelude si, swapped over to h22 vtec if that matters or not. but what you said makes sense i was gonna go with some 195/50/15's i found for cheap but now i know why there so much cheaper then the other sizes.
Old Nov 5, 2009 | 03:31 PM
nsxtasy's Avatar
H-T Order of Merit
Yup, 195/50-15 are a lot smaller. (That's the size older Civics use.)
195/60-15 and 205/55-15 are close enough to each other that you could use either size on either model. I think you'll probably find that there are more choices of performance-oriented tires in 205/55-15 than 195/60-15 though.
Old Nov 5, 2009 | 06:24 PM
RSZero1's Avatar
Forget my advice, I am apparently full of misinformation. I ran 225/45/15 on my 93 prelude just fine. And again, that is why I made sure to state that my information was based on past experience and also depended on what look he was going for. I also agreed Nsx gave the CORRECT in formation.
Just because I have an old civic now doesn't mean that's the only Honda I have ever had exp with.
Old Nov 6, 2009 | 08:43 AM
DrZFiNeSt's Avatar
Dito.You can get away with 195/50/15 on an EK,EG,or DC.Won't work on an Accord or Prelude.
Old Nov 6, 2009 | 10:36 AM
PURP's Avatar
I hear ya, man. Don't worry though... some of us in here CAN read.
BTW
195/60/15 OD = 24.21
225/45/15 OD = 22.97
drop of 5.12%
Most tire sellers will tell you that 5.12% is too much... but only to cover their own ***. It works fine in reality as long as you know that there will be some very minor changes (lower ride height, higher speedometer readings, etc.). I've been riding at +4.89% for the last couple of years....
For all your size conversion questions, I HIGHLY recommend this:
http://ejelta.com/tiresize/index.html
Old Nov 6, 2009 | 03:37 PM
nsxtasy's Avatar
H-T Order of Merit
WRONG. This is BAD ADVICE. It can indeed have negative effects, not only on the accuracy of the gauges but on everything from the suspension geometry to the possibility of rubbing.
Every car is designed to have a certain diameter tires in the wheel well. You can vary within 1-2 percent of that diameter without problems. Differences of 5 percent are HUGE and are asking for trouble. DON'T DO IT.
bmwracer316
Aug 15, 2007 08:32 PM
Civicse
Aug 29, 2006 05:57 PM
krayjeegsr
Jan 4, 2006 03:51 PM
jdmhatch3
Aug 11, 2005 04:50 AM
Indiana Jones
Jun 3, 2005 10:46 AM
