Rear defrost not working. Switch light inversion.
Old Nov 5, 2009 | 06:32 AM
Luvshok's Avatar
Default Rear defrost not working. Switch light inversion.
Ok so as it turns to winter I need to fix my rear defroster. Now while i have not done any major diag on it yet I did go through and check for fuses and what not. I ended up having a burnt out switch, so I replaced it.
Switch did not fix the problem. But whats weird now is that when I turn the lights on the Switch does not light up, but when I turn down the dimmer switch the amber bar on the defrost switch is nice and bright like the defroster was on and working.
Any inside would be greatly appreciated
Thanks
Old Nov 5, 2009 | 06:48 AM
PURP's Avatar
Icon2 Re: Rear defrost not working. Switch light inversion.
I had this same problem with my fog/driving light OEM switches, which are identical in function to the defrost switch. There are five wires coming out of the switch, and I WAS able to figure out which two allow the lights to be turned on and off, but the other three....? One of the two switches works perfect, but the other one (which is wired identically????) dims inversely to the dimmers position and the indicator light sometimes comes on... sometimes not. I checked the bulbs and they work fine. I downloaded the wiring schematics, but of course the wire colour codes don't match the wires coming out of the pig-tails....
Does anyone know what the pin assignments are?
eg.
pin 1 = +12v
pin 2 = ground
pin 3 = switch leg for lights
pin 4 = voltage from dimmer
pin 5 = ????
Old Nov 5, 2009 | 02:47 PM
Luvshok's Avatar
Default Re: Rear defrost not working. Switch light inversion.
Also ive had 2 different switches in excluding the burnt out one and both do it.
Old Nov 5, 2009 | 03:17 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Viewing the Rear Window Defogger Switch connector from the wire side, from Left to Right:
A - BLK/YEL - 12V from fuse 13
B - BLU/YEL - to rear window defogger relay in under-hood fuse box
C - BLK - switch ground
D - RED/BLK - 12V from dashlights fuse 19
E - RED - to dashlights dimmer
Old Nov 5, 2009 | 03:20 PM
deschlong's Avatar
Loved
Community Favorite
^^ Crud. You wanted the pinouts for the fog lights, didn't you.
To the OP: I would check if you have a ground issue, first. The amber indicator light stays on constantly? Can you turn it on or off with the switch? Does it dim with the dimmer?
Old Nov 6, 2009 | 03:41 AM
Luvshok's Avatar
Indicator light only comes on when the headlights are turned on, and then its opposite of the dimmer, so dash dim = indicator bright; dash bright = indicator dim. And trying to toggle the switch does not effect the indicator light
Old Dec 28, 2009 | 12:57 PM
jenksx5's Avatar
New User
I have the same problem with my 94 accord. I checked voltage at the connections on the defroster, i have 14 volts on the drivers side and nothing on the passenger side.
Any ideas?
Bertsch911
11
Dec 24, 2019 06:01 AM
WhiteNeko
Oct 22, 2012 01:53 PM
aziaticvang
Jan 17, 2008 08:56 AM
SigmaOmega
Jul 17, 2005 06:55 PM
al_r
Oct 18, 2003 07:28 AM
