Transmission and axles
Old Nov 5, 2009 | 03:32 AM
Hondaisok's Avatar
Default Transmission and axles
My 91 hatchback std is shifting hard, even when the engine is off so I'm thinking its the clutch. The linkage doesn't appear to be bad. Although I am using a bolt instead of a roll pin for the linkage, but have been doing that for a couple of years now w/out any problems.
Anyway, I have a 5spd transmission of the same year with almost new clutch components that I'm going to replace my 4spd with. I believe everything will match up as long as I am using the same axles?
Question: Do I really need to remove the axle from the hub?
I'm thinking all I really need to do is to disconnect the lower ball joint and pop the axle out of the transmission and move it out of the way.
Old Nov 5, 2009 | 03:47 AM
theft24's Avatar
Default Re: Transmission and axles
thats how i do mine no need to seperate the axle from the hub
Old Nov 5, 2009 | 10:38 AM
Hondaisok's Avatar
Thats what I thought.
Though now that I have done some searching on this forum, I'm dreading doing this as it seems to be a pain to get the transmission back on again by oneself.
VTECROAR96typeR
Suspension & Brakes
Feb 21, 2009 08:27 AM
keepitngga1
Dec 21, 2006 05:00 PM
tekkynikality
Oct 27, 2004 02:12 PM
95gsr
Jun 1, 2002 12:32 PM
Prelussion
Nov 15, 2001 12:51 PM
