98' Accord coupe stalling
Old Nov 5, 2009 | 03:25 AM
tonyasleep's Avatar
Post 98' Accord coupe stalling
Hi,
I own a 98' Accord 2L vtec coupe.
5-6 months ago it developed an internittent stalling issue. No warnings, engine cuts out whether on drive/road/motorway.
As per other threads I have changed the ignition switch to no avail.
Does anyone have any ideas as to the problem?
Many thanks in advance
Tony
Old Nov 5, 2009 | 08:36 AM
z395civic's Avatar
Default Re: 98' Accord coupe stalling
sounds like a main relay
Old Nov 5, 2009 | 03:35 PM
accord99power's Avatar
Actually i had the same problem on my 99 2.3l, but i havent had it happen in a real long time. If i remember right i cleaned out the map sensor, clean of throttle plate and ran intake system cleaner through the intake. Seemed like that fixed it. But i had same issue but mine was like one every 3 weeks very spuratic.
make sure you check your grounds every where and positive wire to the battery.
just some suggestions.
Old Nov 5, 2009 | 03:36 PM
the main relay would be a more consistent problem.
Old Mar 9, 2010 | 12:08 AM
tonyasleep's Avatar
Many thanks for all the advice, I think I've nailed it this time .......yes that old Main relay!!!
It was cutting power to the fuel pump circuit hence the cutting out. I have resoldered all the joints and given it a good dose of WD40 lubricant and am currently searching for a back-up (just in case)
Many thanks again
Tony
bassysingh
Mar 8, 2010 04:21 AM
cr-sex
Aug 8, 2006 12:50 AM
adrift77
Jan 8, 2006 03:30 PM
elpapicometoto
Jan 4, 2006 08:26 PM
