FL FT: 1995 Jeep Cherokee lifted
Any chance anyone would be interested in trading for a 1995 jeep Cherokee and 6x8 open trailer?
I will also sell this set-up as a whole for $2700 obo!
I have a 1995 Jeep Cherokee 4dr, 5-speed (ax-15), 4wd (np231 t-case), 4.0 HO motor with 250,xxx miles. It will also come with a 2007 6x8 open trailer that has new tires, custom tool/storage box, and bass pro shop wheel lift
3" rough country lift with 2" Rustys spacers in front/shackles in rear
Rustys steering box brace
Rustys transfer case drop
Rustys brake line extensions
Rustys interior roll bar
cut front/rear fenders
custom snorkel
custom roof rack with hi-lift jack and two KC lights
electric fan
*new* starter
*new* alternator
*new* clutch/pressure place/throw out bearing
*new* slave cylander
*new* plugs, wires and dizzy cap
*new* idler pully
*new* transfer case chain
*new* fuel pump/filter
*new* air filter
*new u-joints in front drive shaft*
17" pacer wheels wrapped in 265-70-17 Maxxis Buckshot's (one just recently got a flat so the spare is on, the spare tire is a new Cooper Discoverer STT 31-10.5-15)
tow hitch w/ 2", 1-7/8", and d-ring will come with also have brand new Rustys 3.5” leaf packs to replace the old leaf packs and lift blocks
no carpet or head liner
what it needs/will need:
-front brakes will need to be changed soon, rears need to be changed
-rear main is a little leaky
-front diff input seal needs replaced (which I have the new seal)
-both front tires will need to be changed soon
-needs an alignment
-tranny shifts into all gear but going into and comming out of 4th is sticky most the time and it sometimes grinds going into 3rd
-a/c compressor bearings are going so it squeels when you first start up
-i am in the process of trouble shooting a hesitation problem that i will explain more into depth in person
-needs new windsheild
-speed-o gear is broke
will get pictures later today after i wake up. any questions please e-mail race_fox2001@yahoo.com
i am located in Valparaiso, Fl, 32580
custom snorkel
electric fan
*new* starter
*new* alternator
*new* idler pully
*new* air filter
-needs an alignment
HondaMPower
Dec 5, 2003 10:39 PM
