need some help with a swap i just got
Old Nov 4, 2009 | 11:40 PM
fallingxlove's Avatar
Default need some help with a swap i just got
so i just got a d16z6 swap in it. has a b16 ecu i think its pw something forgot wat lols. a6 tranny used my old wiring the guy did some wiring work to get vtec to work and stuff. use i think a ls dizzy which doesnt match up so its cut and mounted weird. but basiclly it was all running good except for a wistle sound which i assusme is a vacume leak. also im getting cel light code 23 which is knock sensor i belive which is not important cause i dont have one right?
so i took out my spark plugs. to do a compression check on my new motor. but one spark plug is stuck. it has like build up rubber all along the sides. so yah. so i tried removing the rest and doing the check with 1 in the head. either the gague is broken or something if messed up because 1st cylnder read 90 psi and second read 30. which i dont think the car would start if that happend. so then i just put everything back together. started the car and it sounded like a go-kart i checked the plugs serveral times everything is connected. the car has no power just stutters bearly moves. sounds like a go-kart its bad.
what should i do? please help and thank you.
also if u call me a dumb ***. sorry hahah but still help
Old Nov 5, 2009 | 12:04 AM
BiG ChOr!Zo's Avatar
Default Re: need some help with a swap i just got
i dont have any answers only suggestions that might get you the help you need...please rewrite your paragraph using proper grammar because its not so bueno...!!!
Old Nov 5, 2009 | 10:55 AM
lol really...cause i misspelled like 2 words my grammer is not right now? intersting. cause i was pretty sure this is a car forum not a english class. thats just me. i re read it everything is pretty understandable
Old Nov 5, 2009 | 10:59 AM
their are more than 2 errors and its not that this is a english class but a chance for someone to actually understand what you are asking about
perfect example:
i wrote my first responce over 11 hours ago and there is yet for someone to give you a solid response about your issues...im telling you once people see the first couple sentences you wrote they are gone quicker than a bat out of hell...!!!
nycpatron
Nov 17, 2012 08:20 AM
eg-6 life
Sep 25, 2011 12:04 AM
91' LS-VTEC
13
Jan 12, 2006 08:25 PM
SOHCEK-Turbo
16
Feb 13, 2005 07:47 PM
sabertooth
Jun 7, 2004 11:51 PM
