B16A2 V-Tec cuttin in and out!!!!!!!
Old Nov 4, 2009 | 11:01 PM
nova55's Avatar
Default B16A2 V-Tec cuttin in and out!!!!!!!
alright i know vtec is ran by oil pressure...... i just changed my oil like just under 2000 miles ago and last night i cot on it in first through 3rd and right at bout 7200 rpm the vtec cuts out then at 7600k its back then out again at 8000k redlines at 8300k....... i change my oil religiously every 5000 miles and every third change i run z-max...... and i have always used royal purple 5w30 since the day i bought my car...... now heres the kicker the owner before me (65 yr old woman) had the valves adjs at 85000 miles...... could that be my problem????? or do i have bigger problems??????
its a 1999 honda civic si w/ 182,125 miles......
plzzzzzzz...... help me ive tried everything but i just cant put my finger on this. its pissing me offf like no other....... this car is my baby and i just cant stand this ****......
Old Nov 5, 2009 | 04:45 AM
RyanA's Avatar
Default Re: B16A2 V-Tec cuttin in and out!!!!!!!
Check your oil level first. If it's full, check oil pressure. If pressure drops, VTEC will disengage. Slight chance it's wiring but I doubt it. I also doubt that the valve adjustment was the problem either. I'd say if it was, you would have had problems a LONG time ago. It's been fine for 100k miles so I doubt her 85,000 mile adjustment is causing problems.
I'd suspect an oil pressure issue. Could be due to worn internals, DENT IN OIL PAN (most common), or just low oil level.
Old Nov 5, 2009 | 05:39 AM
curioso's Avatar
like ryana said check oil pressure dents on oil pan
also have u change ur oil pump??? if u havent is time to change it
Old Nov 5, 2009 | 01:45 PM
shogee's Avatar
take out the solenoid and check the screen if its plugged with stuff, clean it out
Old Nov 5, 2009 | 05:02 PM
nova55's Avatar
hey man thanks for the tip i just might have to try that i never thought of evn doing that i might be pluged i hope that all that is wrong
tigasin
Nov 14, 2008 11:58 PM
karkrazy9
Jun 29, 2008 07:35 PM
carotman
Jun 19, 2007 11:03 AM
99scivic
Jun 1, 2004 11:09 PM
01-1293
Oct 9, 2002 03:03 PM
