Is a b18a1 dizzy plug and play on a 89 civic si?
Old Nov 4, 2009 | 09:47 PM
ninty1civic's Avatar
Default Is a b18a1 dizzy plug and play on a 89 civic si?
Does a b18a1 td24u dizzy plug and play on an 89 civic si?
Old Nov 5, 2009 | 07:05 AM
Default Re: Is a b18a1 dizzy plug and play on a 89 civic si?
no one knows huh?
Old Nov 5, 2009 | 07:11 AM
jlicrx's Avatar
the harness connectors will plug right in, but the distributor will not bolt onto the head
Old Nov 5, 2009 | 07:23 AM
i dont mean onto a d16 or d15.. I know it wont bolt on to the d seires thats just obvious lolz..
Old Nov 5, 2009 | 07:28 AM
the harness connectors plug right in.. but the 2 wires on the small plug are oppostie.. When the two small connectors are plugged together the black/yellow wire matches up to the blue wire.. and visa versa..
Old Nov 5, 2009 | 07:32 AM
SO, does this mean the big plug is going to be wrong too?
Old Nov 8, 2009 | 07:04 PM
no one knows.... crazy
Old Nov 8, 2009 | 07:15 PM
crx_si-r's Avatar
99.9% sure it will work fine
0.01% unsure if car has been modified and the engine harness isnt stock
Old Nov 11, 2009 | 11:33 PM
the car was completely bone stock before he put the the swap in.. and it was not plug and play.. plan and simple was not plug and play, we had to switch the rpm and coil wire on the small plug.. which makes me believe wires on the big plug arent plug and play either, but thats what im trying to figure out..
Timothy Yhtomit
Mar 4, 2019 06:36 PM
civicfan18
Jun 16, 2017 05:31 AM
jdmd15hatch
Apr 19, 2013 09:34 PM
Nicaraguense13
Jul 27, 2008 11:44 PM
