ash tray light on 95 teg
Old Nov 4, 2009 | 08:37 PM
robcivic559's Avatar
Icon6 ash tray light on 95 teg
does any one know how to fix the ash tray light i got light from the lighter but not the tray anyone
Old Nov 4, 2009 | 08:52 PM
GagnarTheUnruly's Avatar
Default Re: ash tray light on 95 teg
Pop the tray out and have a look to see if the bulb is out or if the connector is loose:
1) Pull out the ashtray, all the way
2) You can see three screws behind where the ashtray was, unscrew the two outer screws (I think you can leave the center one in)
3) Pull out the ashtray/lighter assembly and disconnect the connector. Inspect the connector for loose wires and inspect the ash tray lightbulb (I think it's a bulb -- if it's an LED you know you've got a bad connection).
If you have a multimeter you could try to do some continuity testing if the bulb seems OK.
Old Nov 4, 2009 | 08:54 PM
TonySemi's Avatar
it is a bulb, and excelent advice!
Old Nov 4, 2009 | 08:57 PM
the light ring work and it connected it the bullb do you know were i can buy one at
thank 4 the help
Old Nov 4, 2009 | 08:59 PM
a97b18b's Avatar
I gotta go check on mine..I didn't even know there was a light bulb there till i read some thread. My cig lights up when ever it wants too. Hopefully sometime soon i'll replace all my bulbs for climate control, ash tray and cig lighter. I hate how I have to tap at the top of the C.C to turn on a few lights on the controls
Old Nov 4, 2009 | 09:28 PM
thank 4 the help
It can't be anything too exotic -- it's not like Honda makes their own. I'd try either a RadioShack, a hardware store, or an auto parts store. Failing that, I'm sure the internets has one or two lying around.
marcus81184
Mar 18, 2009 05:02 PM
SuNDaY DRiVeR
Aug 26, 2005 02:18 PM
motormanSR
Oct 4, 2004 06:36 PM
animated_life
Dec 27, 2003 12:03 PM
