Misc. stuff for sale 'cheap'
I have some stuff laying around that needs to go. Prices include shipping. If you think it's unfair then make me any offer that is reasonable. I'm located in Western Maryland 21502. Prefer pick on the ls motor. Thanks for looking.
"01 integra" uncut obd2-b engine harness 70 shipped
obd2 ls intake manifold 40 shipped
obd2 throttle body with good tps and map 40 shipped
94 ls motor that needs rod bearing/s ONLY 'block and head' 150 picked up
phoenix gold ryval V754 4ch amp 1000 watts "new" 100 shipped The box is for another amp.
2 brand new aluminum fittings 'good for valve cover breather" 1/2" npt to 5/8" hose/barb 20 shipped
ls upper/lower timing covers 25 shipped
obd2 ls/b20 valve cover 'perfect for cutting to show cam gears' 30 shipped
look at pictures to see were it's broken.
3 filters 2 k&n and 1 no name 12 shipped each or 30 for all 3 shipped. none have been used ever
The no name filter is 3" round 3.25" tall W/flange and has 1.5" inlet. Specs on k&n filters are
K&N Filter 62-1370 "smaller one"
Rubber Base Crankcase Vent Filters
Flange Inside Diameter: 1 in (25 mm)
Outside Diameter: 2 in (51 mm)
Height: 1.5 in (38 mm)
Top Style: Metal
Top Material/Finish: Chrome
Flange Length: 0.625 in (16 mm)
Flange Type: Centered
Flanges: 1
Inner Wire: No
K&N Filter 62-1390 "bigger one"
Flange Inside Diameter: 1.25 in (32 mm)
Outside Diameter: 3 in (76 mm)
Height: 2.5 in (64 mm)
Top Style: Metal
Flanges: 1
Inner Wire: No
Top Style: Metal
Flanges: 1
Inner Wire: No
Top Style: Metal
Flanges: 1
Inner Wire: No
LBR92DA-T
Jan 21, 2005 08:30 PM
TurBoTeG
Oct 25, 2003 12:48 PM
