And the stock DX front anti-sway bar is...
Old Aug 30, 2002 | 08:46 PM
FourthGenHatch's Avatar
Default And the stock DX front anti-sway bar is...
18mm or 19mm? I thought it was 18, but I need to know to order some bushings.
Old Aug 30, 2002 | 09:49 PM
the DR.'s Avatar
Default Re: And the stock DX front anti-sway bar is... (FourthGenHatch)
pretty sure its 18mm
anyone else?
Old Aug 31, 2002 | 05:31 AM
wronghand's Avatar
Default Re: And the stock DX front anti-sway bar is... (CIVICtypeS)
Si = 19mm
DX = 18mm
HF = 17mm
Old Aug 31, 2002 | 05:42 AM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: And the stock DX front anti-sway bar is... (wronghand)
Si = 19mm
DX = 18mm
HF = 17mm
you sure Si and DX aren't the same bar??
why would they produce two bars, only 1 millimeter difference?
Old Aug 31, 2002 | 06:06 AM
wronghand's Avatar
Default Re: And the stock DX front anti-sway bar is... (two.oh)
I wa basing my answer on information I found at both quickhonda and the CRX resource. After you quesiton I researched it a little further. Based on Majestic Honda the Si and DX do have the same sway bar. The HF is different. However majestic did not give the size. I was then forced to walk outside in the rain to measure the extra Si bar I have. It is 18mm.
I hope this helps.
By the way I am pretty sure that the HF is 17mm.
Old Aug 31, 2002 | 08:51 AM
civbeater90's Avatar
i'm almost postive also that it is 18mm
Old Aug 31, 2002 | 07:05 PM
Default Re: And the stock DX front anti-sway bar is... (civbeater90)
I thought it was 18 to, and I'm positive if Si isn't 19 then DX sure isn't gonna be bigger.
railsk8a
Feb 3, 2011 04:30 PM
vegaskurt
Feb 4, 2005 12:18 AM
ApexiChild
10
Mar 1, 2004 04:13 AM
NINJASPY
Jul 11, 2002 04:15 PM
TheShocker
Oct 16, 2001 10:39 AM
