question
you will have to modify ur caliper hold-down bracket (custom) and u will need bigger rotors and depending of the size of ur wheels u might not fit the caliper through the wheel well either
and wasup eg sleeper yes ur right about them not being a direct bolt on affair
yessir. the smallest size wheel you will be able to fit over that caliper is a 16. i did some searching around. you will need to locate a 4x100 lug pattern caliper that is almost the same size as a rsx rotor. type s or regular are different sizes, make sure you get the rotor to match the caliper. honestly its not probably the best brake swap you can do.
Alright then thanks i aprriciate the help theres one at a local junk yard and has to complete braking system thought maybe i can take use since its dirt cheap lol but thanks!
El3ments
Mar 25, 2012 03:06 PM
crex23
Acura TL, RL & ZDX
Aug 8, 2003 06:53 PM
