f22b2 Shaking [Seems like car is slower]
Old Nov 4, 2009 | 02:19 PM
Zendos's Avatar
Default f22b2 Shaking [Seems like car is slower]
Well i was just driving and i noticed that my car was shaking, i was near a shop so i just went and got my oil changed, problem still was there. So i went home and did a few tests, and i decieded to check to spark plugs, and this is what i come to find out.
One Spark Plug Is Dry and has no oil.
You can see how it looks compared to the other ones, but im not sure if this would be a problem. Can someone help me.
Old Nov 4, 2009 | 02:46 PM
B16acivicsedan91's Avatar
Default Re: f22b2 Shaking [Seems like car is slower]
You need a new valve cover gasket, there should not be any oil on your spark plug wires.
Old Nov 4, 2009 | 03:02 PM
Zendos's Avatar
what can cause oil to be on them then? all i remember is trying to take off the valve cover so that i can paint it, i pryed it just a little bit but stopped. and put it back to place. I also forgot to mension that i disconected some air tubes but i put them back into place. And the problems didnt concist until after i tryed that stuff yesterday.
Old Nov 4, 2009 | 03:38 PM
Zendos's Avatar
How much would a new gasket cost? and what normally causes it to wear>?
Old Nov 4, 2009 | 03:53 PM
Eli2's Avatar
So the shaking didnt start until you tried to remove your valve cover correct?
Its made of rubber and it rots and it also didnt help that you took the valve cover loose. You need to replace the spark plug tube seals not the valve cover gasket but you should do it anyway while your in there. Also you could have a bad plug wire and the puddle of oil is causing it to ground out to the motor if that makes sense to you.
If you removed vacuum lines did you make sure to put them back where they came from and that you didnt rip any of them as that would cause a bad idle problem.
Old Nov 4, 2009 | 04:02 PM
Zendos's Avatar
yeah i put the lines back together. but how serious is this problem?
Zendos
Nov 4, 2009 04:04 PM
01blackcivic
Honda Civic (2001 - 2005)
10
Jan 27, 2009 11:34 AM
smetzger
Oct 12, 2006 11:57 AM
Mike17
Feb 11, 2004 02:31 PM
IamVtec
Apr 8, 2003 01:22 PM
