More Rear Disc Brake Questions!!
1. Are the pads on the 90-93 Integra Rear Discs the same as the 2G CRX Si?
2. If I get SS lines, should I get the ones for the 90-93 Integra, and they will be fine with my stock front?
get 91 crx si 4w disc lines or 92-95 4w disc....i have 92-95 no abs 4w disc... the lines run a little different but work(in the rear) the front work perfect
yes.
yes.
Ok I just wanted to know because my setup is Brembo Blanks w/ Honda Pads and it works great in the front so for a cheap setup I'm doing the same in the rear.
And driverfx.com says the trailing arm bushing will fit Civic/CRX and Integra.
spettinger
11
Sep 26, 2002 08:18 AM
