SRS light on... need some help
Old Nov 4, 2009 | 12:56 PM
Flipimp1's Avatar
Default SRS light on... need some help
Ok guys, installed an AP1 wheel in my EK yesterday, and actually got the cruise to work on the wheel! Regard a prior post. Anyhow, hooked up the connector under the dash, and the one in the actual steering wheel. Both plugs matched up fine (AP1 wheel and civic airbag harness). Problem is my SRS light has not turned off. Does anyone have any suggestions to fix this problem? Thanks!
Old Nov 4, 2009 | 01:14 PM
fungus mungus's Avatar
Default Re: SRS light on... need some help
Does the horn work?
fm
Old Nov 4, 2009 | 01:19 PM
Ferio4ya's Avatar
i believe SRS is for airbag. check airbag connections. its yellow plastic tubing wiring inside.
Old Nov 4, 2009 | 01:23 PM
I ask if the horn works because if it doesn't (and it's hooked up), the clockspring may be broken.
fm
Old Nov 4, 2009 | 01:57 PM
Flipimp1's Avatar
Horn works. Connections are good. Does it need to be reset?
erck
Jun 8, 2007 07:34 PM
EK4_JOSE
Mar 24, 2007 08:55 PM
Elmo1968
Oct 11, 2006 05:47 PM
b18c-ivic_gsR
Oct 20, 2004 08:09 AM
servion
Jan 14, 2002 01:54 PM
