New NepTune RTP Release (OnBoard Logging, Anti-Theft, and MORE!)
Old Nov 4, 2009 | 11:22 AM
93turbo16's Avatar
Default New NepTune RTP Release (OnBoard Logging, Anti-Theft, and MORE!)
Today Hrtuning released a new version of the NepTune code base.
It has some amazing new features that no other OBD1 Honda Rom editor has and after beating this new code base to death it is now ready for release!
The updates are for Dealer and RTP versions of the software. So to add any of the new features you just have to go back to your dealer/tuner and they can be added to your existing tune with no problems!
On Board Logging is available for ALL Demons. If you already have one just update the firmware by following the directions in the NepTune Help.
If you have an older RTP ALL features except for On Board Logging will work for you too!
All you have to do is open your current calibration with the new version of the software and upload base code. You're now running the new code base. No changes are necessary to the tune for it to run the same.
Some of the new features included in this release are:
- Anti-Theft
- Onboard Logging (RTP)
- Closed Loop Wideband Support
- Gear Based Rev Limits
- Gear Based Shift Lights
- Access to TPS trims
- Access to Idle Ignition Corrections
- Ignition Dwell Control
- Access to Ignition Limitation Tables
- ECT Protection
- And much more!
New Live Graphing window!
Anti-Theft - Uses a combination of input switches and Gas/Brake Pedal pumps to deactivate the anti-start settings. You can choose whatever combination suites you.
My current setup is 1 pump gas, 2 pumps brake (hold the 2nd pump) since i have the brake switch input checked.
If you do not enter this combination correctly the car will not start!
- NepTune combined with the Demon now offers a great source of onboard logging.
There is a wide array of activation and deactivation parameters for logging that can fit any situation.
You can select multiple sample rates so you can have short precise logs or longer less sampled logs for longer trips.
Also combine this with 255 slots for logs to be saved on the demon you can log a whole track day with no problem.
Closed Loop wideband - This allows you to choose a target voltage for your wideband.
Just run your 0-5v from your wideband to one of the 4 inputs in the drop down menu and set your target voltage to where you would like to be in closed loop.
Old Nov 4, 2009 | 11:30 AM
DDTECH's Avatar
Default Re: New NepTune RTP Release (OnBoard Logging, Anti-Theft, and MORE!)
Yep, was testing it yesterday with craig while they were doing some new stuff its AWESOME.
Old Nov 4, 2009 | 11:33 AM
HRTuning's Avatar
Wow, that was quick...
Just to be clear here. On Board Logging is available for ALL Demons. If you already have one just update the firmware by following the directions in the NepTune Help.
If you have an older NepTune RTP ALL features except for On Board Logging will work for you too!
If you have eCtune, I'm sure you'll have something available to you in a few weeks or so.
Old Nov 4, 2009 | 05:53 PM
Top Ramen's Avatar
Default Issues
Just updated my software and it deleted all my preferences, deleted my serial number and deleted my target A/F ratios. I have re-entered the serial numbers and it still refuses to connect. I would really love to be able to tune my car.
Old Nov 4, 2009 | 06:21 PM
93turbo16's Avatar
Default Re: Issues
All you should have done is put the new NepTune Program in your old folder.
What I would suggest is just make a copy of your old folder and then copy/paste the new neptune.exe into that folder. That way it saves all your preferences and serial numbers.
If you have any specific problems/questions just make a post on the forum and they will be straightened out quickly! www.hrtuning.com/forum
Old Nov 4, 2009 | 06:26 PM
MONSTERek4's Avatar
wow neptune for sure just took a **** on hondata hahahah
Old Nov 4, 2009 | 06:35 PM
HRTuning's Avatar
Default Re: Issues
Like I said in email, nothing has been changed with the preference system. You either ran an older copy (WAY old) that didn't support the latest version of the preference file or you're not running it from the same folder your preferences are in. If there was an error reading the preference file you had it would have told you so with an error message.
Old Nov 4, 2009 | 06:50 PM
Top Ramen's Avatar
Default UPDATE
As usual, got excellent (and very patient) customer service from Neptune. I used Time Machine to restore all of my files to the state they were in just before the update, then re-installed it. Everything works fine now. I think some of the links were broken during the first update even though I kept everything in the same folder.
Love the new features.
Old Nov 4, 2009 | 07:04 PM
HRTuning's Avatar
Old Nov 4, 2009 | 07:28 PM
mtber's Avatar
I like the graphing. Nice job.
Old Nov 4, 2009 | 08:09 PM
HRTuning's Avatar
Thanks. The graphing has looked like that for a very long time. Live Graphing was added two releases or so ago. Pretty neat stuff!
Old Nov 5, 2009 | 12:21 PM
hatch2wenty2wo's Avatar
Awesome stuff. Thanks as always for listening to your customers request for features.
Old Nov 5, 2009 | 12:24 PM
HRTuning's Avatar
No problem at all.
Old Nov 5, 2009 | 01:45 PM
Turbogixxer's Avatar
Yes, James has always listened to what I ask for. I love working with him.
cuky787
Apr 10, 2017 12:13 PM
89 pos
Nov 30, 2005 03:40 PM
taikahn
Jul 8, 2005 05:07 PM
RacerDataDisplay
Feb 2, 2005 08:20 PM
