d16y7 intake mani.
Old Nov 4, 2009 | 11:11 AM
Clean_Ej6's Avatar
Default d16y7 intake mani.
How do you remove a d16y7 intake mani im taking the hole motor out and want to take it out to make things easyer so help please.
Old Nov 4, 2009 | 01:56 PM
D Griff's Avatar
Default Re: d16y7 intake mani.
It's pretty easy. Remove all the wires going to it, they're all just plugs, no cutting. Label them so you don't get mixed up later. Remove the hoses (coolant will spill out), vacuum lines... Depressurize your fuel system and remove the connection at the end of the fuel rail. The manifold has 8ish bolts attaching it to the head and 1-2 under it on a bracket.
Look for a Y7 to Y8 manifold swap write up, there are good ones out there.
Old Nov 4, 2009 | 01:59 PM
R666_EK's Avatar
It will give you ZERO issues when trying to remove the engine. I did it to mine. I only removed the exhaust manifold. Motor and trans came right out with no problems.
Its easy to remove, but not necessary...
damechanic
Jun 5, 2014 08:16 AM
14psi
Aug 9, 2013 08:39 AM
USDM EG
Honda S2000
26
Jul 20, 2007 03:14 AM
coreyhayman
Sep 29, 2006 06:38 PM
