Interchangeable TPS's For 1991, DA9
Need a TPS. Some where in between the next two days, Im heading to the Junk in search for a TPS. I did my research and know for a Fact that 1990 will be interchangeable. Question is What other TPS's are Interchangeable with my 1991 Acura Integra other than 1990???
Thank you.
Thank you.
90 91 are obd0 and thats why you can interchange them but Im not 100% sure you can use a 92 93 cuz they are obd1 but if you happen to run into one of this cut the connector in case they are not the same that way you can rewire it
1991, 91, accord, acura, da9, honda, integra, interchangable, interchangablility, interchangeable, position, rs, sensor, throttle, tps, transmission
