cold air intake install help
2 questions so go easy on me people: i have a 92 lude
1) i have go an ebay CAI and was wondering if anyone has pics on how to install the easy way ...?
2) also it says is carb aproved on the box but had no sticker or nothing for proof, so can i print this chart and use it against a cop in california if one pulled me over.. please help... ? heres the link
http://www.kstreetstudio.com/hpde/notes/carblist.htm
its number D-533 (first row down, column 17 across), sounds confusing but can i use this as proof that my intake is CARB legal
You're going to have to make the hole going into the fender well bigger, ether by using a hammer or cutting. I also had to make a bracket to make the CAI bolt to the car. I have a Bomz CAI.
make the hole bigger? not correct. the piping should line up with the hole just fine. The filter is what will cause fitting problems. If the filter wont fit on your piping, then i'd reccomend getting one that does. (a narrower filter) I have an AEM and it works just fine. side note: i know this is true because i also cut the hole to fit the larger filter when i first installed. Then, i realized all i had to do was get a different shaped filter.
so i just have to disconnect like one hose and take out the resinator and try to fit the tube through the whole n thats it no other major parts to connect?
also any advice for my C.A.R.B question?
Dude, it's really easy to install. Search for some CAI installs. If it does't have the CARB stamp on it, I'd assume it's not exempt but I'm not an expert on those matters.
i ve looked all over the internet for 92 intake install cant find one anywhere so i asked here, i dnt wanna mess my car up
still pretty pissed bout the carb thing
ok double d, i may be wrong. sorry, i have never dealt with a ebay CAI. however, if my memory serves me correct, the hole is bigger than 3in. I could be wrong. i will look myself when i get off work. Now dont get all pissy, im not saying your wrong. i just want to check myself since you pointed that out.
its not that useful using this when i ask questions on forums i get answers from people who dnt have lives and like to argue with other peoples replys and just takeup space so they can get there rank high replying as much crap as they can but thanks to u that did help me on this question.....
Op re: the cai. Regardless of what brand your using i would recommend widening the hole
the cai goes through into the fender well. I have a aem cai fitted and it fit through the hole but after a couple of months it started to rub, obviously with the movement of the engine and the car. So i widened it and no prob since. I have also seen someone post up a pic of theirs which had a slash cut worn into the cai piping from the metal edge on the hole. As for the install, just take your time with it, its very easy.
point blank just like everyone else said you need to open up the hole. don't want to? get a short ram. the rest should be a pretty basic bolt on. never be afriad to tinker around under there, you've gotta learn something somehow
no HdeucedeuceA i agree with u, just other people where being dumb like always on here but anyways can any answer this, my new problem is this
my cold air intake only has a hole for one hose i was wondering if i install it will it mess up my engine if this hose isnt installed
ok the red arrow has a hole on my new cold air intake but yellow arrow has no hole on my new one do i need to make a hole?
damn u guys are smart....
alright last thing ..... if i take out the resonator and i make the hole bigger and lets say i need to put the stock intake in for sum reason will i be able to or will it not work bcuz of a bigger hole?
