93 civic with b20 vtec dont satart
Old Nov 3, 2009 | 07:38 PM
oneEg1Tc's Avatar
Default 93 civic with b20 vtec dont satart
Help 93 ex with b20 vtec don't turn on. Lights. Are. Working and everything was ok after I parked and try turnnin it on doesn't ...
Old Nov 3, 2009 | 07:43 PM
oneEg1Tc's Avatar
Default Re: 93 civic with b20 vtec dont satart
Help
Old Nov 3, 2009 | 08:24 PM
oneEg1Tc's Avatar
Old Nov 3, 2009 | 08:38 PM
B16Drag's Avatar
You're not giving us enough info boy.
1) Does it turn over?
2) Do you hear the fuel pump prime?
3) Do you feel the main relay click?
4) Did you check all of the fuses under the dash and under the hood?
5) Did you double check the ECU/chip?
6) Any CEL?
7) Have you taken out the spark plugs and made sure that you are getting fuel?
8) Did you check if you had spark from the distributor?
Old Nov 3, 2009 | 08:53 PM
oneEg1Tc's Avatar
Ok so I jump started and turned on but if I shut it off and tried to started again it doesn't , it doesn't click, turn or nothing , but radio and lights work tho !
Old Nov 3, 2009 | 08:54 PM
oneEg1Tc's Avatar
No cel, all fuses ok,
11winkler
14
Apr 24, 2012 06:32 AM
GHOSTFACE_B20V
Jul 16, 2009 08:22 AM
MrMug3n
10
Nov 6, 2008 08:43 AM
ha...tch
Jun 11, 2008 06:36 AM
Melt
Jul 27, 2004 01:35 PM
