D16Z6 Engine w/ P30 ECU??
Old Nov 3, 2009 | 02:02 PM
Tong.Y's Avatar
Default D16Z6 Engine w/ P30 ECU??
Will it be a problem with a single cam motor to Run an origional Dohc Motor ECu?
will it cause problems? will it still able to perform vtec?
Old Nov 3, 2009 | 04:35 PM
mtber's Avatar
Default Re: D16Z6 Engine w/ P30 ECU??
You should either have the p30 ecu chipped for the d16z6 motor setup or you should be running a p28 ecu.
Old Nov 3, 2009 | 05:15 PM
Tong.Y's Avatar
If it's Chipped will It Still be able to run a dohc motor?
Old Nov 3, 2009 | 05:52 PM
mtber's Avatar
Yes
Old Nov 4, 2009 | 02:53 PM
SolAssassin's Avatar
That DOHC ECU has a knock sensor board. You'll run in limp mode because it's looking for a sensor that you don't have. Get good money on eBay for that ECU and then turn around and buy a P28
Zach Barrette
Sep 14, 2017 02:59 AM
1sickeg8
Dec 4, 2009 10:07 AM
sc95delsol
Oct 16, 2007 05:23 PM
91integraLSVTEC
Jan 4, 2005 05:02 PM
