1994 civic auto to manual b18 swap. wiring help!!
yes i have searched but this is my situation
i have a 94 civic. i am doing a auto to manual and all so throwing is a 99 gsr swap.. its obd1.
i have the clutch line and peddels in and everything ran..
but wiring i have no idea what to do..
my dash lights come on. and i turn the key on and all i hear is a small click comming from the fuse box...
for the auto shifter plug .. what do i have to connect. or what other wiring do i have to connect
are your grounds properly connected? is the fuel pump kicking on? the battery connected? are you pushing the clutch all the way in to where you push in the neutral safety switch to crank the motor?
okay this happened to me before and all it was is a fuse blew. check your all your fuses under the hood next to the battery. mine was a 15amp fuse, so double check that as well.
import-tooner
Sep 8, 2012 01:34 AM
hondaluver12
Oct 24, 2011 04:07 AM
importheaven
Dec 2, 2008 08:06 AM
g4hatchie
Sep 25, 2003 04:59 AM
