front radiator support
Old Nov 3, 2009 | 12:44 AM
FormulaIntegra's Avatar
Icon2 front radiator support
on a 95 EJ1 (EX Coupe), is the radiator support frame bolted on, or welded on. I need to replace mine, and am wondering what I'm up against.
Old Nov 3, 2009 | 01:02 AM
ekb16a's Avatar
Default Re: front radiator support
wleded u but not that hard to remove
Old Nov 3, 2009 | 04:29 AM
john666's Avatar
its spot welded. with the bumper off you will see little dots.. drill them out and thats it basicly.
Old Nov 4, 2009 | 09:39 AM
Sounds easy enough. Is it something that should be welded back in place, or can I get away with replacing the spot welds with Grade 8 bolts and hardened washers?
Old Nov 4, 2009 | 09:57 AM
98civdx's Avatar
Master Detailer
weld it, bolt i guess if you want you could bolt it in, i would highly reccomend you weld it
Old Nov 4, 2009 | 12:00 PM
Ferio4ya's Avatar
weld it, that's the proper way to do it.
FOMULA91
15
Jun 17, 2015 11:37 AM
Chriskemp
May 21, 2013 05:58 PM
hectic947
Dec 12, 2010 02:59 PM
Draggin99Si
Northern California (Sales)
Aug 28, 2007 08:42 PM
