Will C.E.L pass smog?
Old Nov 2, 2009 | 10:01 PM
civicSF98's Avatar
Default Will C.E.L pass smog?
I have a 99 civic but my check engine light is on. It has something to do with my speedometer.
Does anyone know if this will affect smog check?
Thanks.
Old Nov 2, 2009 | 10:52 PM
geneeunit's Avatar
Default Re: Will C.E.L pass smog?
you cannot pass smog with a check engine light on.. at least in california you cant.
Old Nov 2, 2009 | 10:54 PM
MHDesigns's Avatar
wont pass here in az so it definitely wont pass in cali...
Old Nov 2, 2009 | 10:58 PM
roycivic92's Avatar
nope and if u take the buld out, the smog machine wil still read it good luck
Old Nov 2, 2009 | 11:02 PM
MHDesigns's Avatar
Is your cel for the vss?
Old Nov 3, 2009 | 09:31 AM
civicSF98's Avatar
I'm not sure, I changed the VSS but my speedo still doesn't work.
It could be the wiring.
Old Nov 3, 2009 | 09:51 AM
Former User's Avatar
Check whether the VSS gets battery voltage and whether the ground wire has continuity to body ground. If those are fine, check the wire running between the VSS and ECU for an open or short. The VSS connector also seems to be a common problem.
Old Nov 3, 2009 | 12:39 PM
boxeocampeon's Avatar
yeah theres no way youll be able to pass
Old Nov 3, 2009 | 12:55 PM
Vindicator9000's Avatar
318 Curves, 11 miles
definitely doublecheck the 3 sockets inside the connector on the VSS wire, as well as all 3 pins on the vss. I've seen them corrode out multiple times.
If the connector on the wire end is corroded, just snag any similar square 3 prong honda connector from the junkyard and solder it on. That's what I did... think mine came off an old Accord. It doesn't have to be a VSS connector, just one the same shape.
Old Nov 3, 2009 | 02:33 PM
EL Vap133's Avatar
What code is it throwing?
JDM Micheal
Mar 9, 2008 10:04 PM
silverandblack
Aug 18, 2007 09:02 PM
Blammo300
Dec 7, 2005 04:45 PM
Vanilla4215
Jul 2, 2002 04:33 PM
