Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
03 honda pilot transmission issues
Old Nov 2, 2009 | 08:51 PM
speeddave's Avatar
Default 03 honda pilot transmission issues
We just recently bought an 03 honda pilot ex-l, and noticed the other day that our "D" gear indicator was flashing, it only did this after and extended period of constant driving. So we pulled over for a bit to feed our little guy and let the tranny cool off and the flashing went away. It only has come on twice and both times it was after extended usage.
Is it possible for me to pull codes from it myself? are they stored or do i have to pull it when it is throwing the code?
any ideas on what it could be or common issues?
Old Nov 3, 2009 | 04:29 AM
NDNV's Avatar
Default Re: 03 honda pilot transmission issues
As you probably know, a flashing D light means the PCM has sensed an abnormality in the transmission. A code should be stored and you should be able to retrieve with a scanner (or the HDS at the dealer).
Old Nov 9, 2009 | 10:00 AM
jwh1276's Avatar
Also, call the dealer as '03 Pilots have had recalls for transmission problems, which your vehicle may qualify for. check it out at edmunds.com.
Old Nov 9, 2009 | 03:07 PM
speeddave's Avatar
awesome thanks guys, i'm going to have the code pulled by the dealer and we'll see what they say. i am thinking its something minor, just because that's the only time its shown up.
maat4449
Honda CR-V & Element
Jan 7, 2011 08:08 AM
grooner
Nov 21, 2010 07:06 AM
arielb1
Jul 22, 2004 05:40 PM
