gsr eating gas
Old Nov 2, 2009 | 08:18 PM
mxracer420's Avatar
Default gsr eating gas
i have a eg gsr swap and i put on a skunk2 intake mani and tb every since then i have been going through gas horribly i am no longer driving it i am waiting to figure it out then ima change the oil and do that so i had put in a obd2 injector and thought it was just bad but i replaced it with a obd1 injector still eatin it. i kow this injector is fine. when the car warms up at idle it is about 1200 rpms and after bout 2 minutes i look behind the car and it is wet with fuel so i know the extra non burnt fuel is getting out but i dont get why its burning gas so bad...car runs perfectly fine drives fine doesnt chug has full power its just burning gas like no other... help please
Old Nov 2, 2009 | 08:33 PM
mxracer420's Avatar
Default Re: gsr eating gas
ttt
Old Nov 2, 2009 | 09:12 PM
thumper64's Avatar
Sure that's gas and not just condensation? What kind of numbers are you getting for fuel economy?
OBD1 and 2 injectors are interchangeable, I believe. You just have to clip a little plastic off the OBD2 injector plug if going on a OBD1 harness.
Old Nov 2, 2009 | 09:25 PM
mxracer420's Avatar
iwent through 3/4 tank in about 50 miles
Old Nov 2, 2009 | 09:38 PM
boxeocampeon's Avatar
change out the o2 sensor
Old Nov 2, 2009 | 09:44 PM
mxracer420's Avatar
im on my second o2 in a 3 month period.
Old Nov 2, 2009 | 10:47 PM
MHDesigns's Avatar
Compression test?
r1ch1e
May 24, 2007 11:34 AM
dem0nk1d
Dec 17, 2006 07:14 PM
