Suspension & Brakes Theory, alignment, spring rates....
eg air cylinders
Old Nov 2, 2009 | 06:43 PM
slow96lude's Avatar
Default eg air cylinders
Just wondering what air cylinders you guys are using on the eg's. I went to airbagit.com and found a front kit for 299. All I want is to be able to adjust the front suspension. If anyone knows a cheap way about doing this with the air ride let me know.
Old Nov 2, 2009 | 06:52 PM
A.E Motoring's Avatar
Default Re: eg air cylinders
no one on here uses air, all mostly coilovers
Old Nov 2, 2009 | 08:19 PM
slow96lude's Avatar
noone at all has air ride. that baffles me. I hate coilovers. my car has lowering springs on it that are just too low. but the ride quality is not bad.
Old Nov 3, 2009 | 08:50 AM
overurhead360's Avatar
I'm interested in air ride also. Though i have coilovers.
Old Nov 3, 2009 | 05:14 PM
slow96lude's Avatar
well I found some really cheap air cylinders off ebay and also on airbagit.com
you just have to buy the two switches and compressor, tank, accumulater (for a better quailty ride), and some fitting and hose. All in all it wouldnt be a bad investment for those pesky speedbumps and bumpy entrance ways into BK.
Old Nov 3, 2009 | 10:36 PM
trevorjohn88ef's Avatar
if your going air stick to a bag and strut. cans will give you a harsh ride and will ride terrible. my buddy thrw together a bag setup for his civic for around 1500.
Old Nov 4, 2009 | 04:20 AM
slow96lude's Avatar
the only problem with the bag and strut( I.E. the new 3 barrel design) is that us with the eg chassis dont have any room for them. Ive seem them on a del sol before, which is pretty much the same suspension as the eg and the struts got hung up sometimes so they had to be welded some cockeye way. Im not really looking to do that. I want a little preoject that can be completed in a day at a shop. I do know if I get an accumulater it wouldnt be that bad. It give the air a little more space to compress therefore a little better ride,
1500 is way out of my range. Im looking to only do the front and just use it to get over the unavoidable **** they call roads down here in flo rida
Old Nov 5, 2009 | 08:44 PM
BaggedFerio's Avatar
use air cylinders....here's the setup I put together....any questions just let me know!
Old Nov 5, 2009 | 11:20 PM
if you had smaller wheels that could look really good
Old Nov 6, 2009 | 12:36 PM
slow96lude's Avatar
ok i got some questions. What cylinders and switches did you use. why not using an air dryer
S1NFUL RL1 619
Suspension & Brakes
Jan 8, 2008 11:55 AM
pcguy760
Suspension & Brakes
16
Oct 8, 2007 01:25 PM
92CivicSIRhb
Suspension & Brakes
Sep 14, 2005 05:33 PM
Overblown-Teg
Dec 15, 2003 09:40 AM
hybridtech
Aug 14, 2003 02:50 PM
