[WI] del sol and random N oddball parts
I have the rear interior piece with teh buckets and covers. its in great condition, and clean. 75 OBO
rear center piece between speaker corners. gray, some scratches. great for a wrap project. 25 OBO
both speaker corner pieces. vynil removed, most of the adhesive removed. was planning to re wrap them. 25 OBO for both.
door sils. black, passeneger side is cracked from changing ecu, not noticed unless looking for it. both sides have normal scratches/wear/tear 30 OBO
trunk carpet minus floor piece. clean, good condition. driver side still has light fixture. 40 OBO
black driver side piece that goes behind the seat and under the speaker, wraps to door edge. great condition 25 OBO
underdash paneling with fuse cover 15 OBO
over? steering wheel panel, small piece 5 bucks
d15b7/2/8 lower outer timing cover 15 OBO
D series clutch and pressure plate. look to be in good condition, low miles. 90-2000 d series fitment, may not fit 88 or 89 transmission styles (measurement problem?) asking 25 OBO
various accessory belts 5 each
used timing belts. spares for if you buy a civic with a worn belt perhaps. 5 bucks each, 3 are laying around. all have less then 10k miles on them.
d15b2/7/8////d16a6 valvecovers one is stock black, paint coming off. 25 OBO second one is customized, timing belt cover smoothed off, shaved stuff, un finished. 30 OBO
D series shift linkage. will NOT fit civic has both bushings and includes shifter and shift **** 100 OBO will sell shifter/**** off linkage for 20 firm, otherwise stays with linkage
front dual tube strut bar. 92-00 civic 93-97 del sol 94-01 integra 25 OBO
front adjustable tie bar 15 OBO
MSD external coil. never used, black, part number 8222 35 OBO
barely used 4 wire O2 sensor bougth new 90, has 50 miles on it, yours for 45 OBO
OBD2 civic cat. nearly brand new condition with only 300 miles. extremely clean. asking 145 OBO
scarebird disc converion. fits rear drum hubs from del sols and possibly 92-95 civics. with this all you need is calipers, rotors, pads, e brake lines, normal brake lines, and possibly a prop valve paid 120, never used, asking 75 OBO
brake booster form 96 ex civic--------\\
brake master cylinder from same car--- offer. separate or grouped
prop valve from same car-------------//
d15b7 motor, 50 with head, 70 100k to 150k miles, previous owner speedo failed. assume 150k miles to be safe. turns over smoothly by hand
2 PM3 heads, 30 each, or 20 if with motor
**PM3 = d15b2/7/8 and d16a6 ojnly difference for d16 is cam, springs, and retainers. both heads are off d15b7 motors, full with cams
d16a6 camshaft and d16y7/8 cam gear 70 OBO
ODD PARTS
metal bracket for D series manual linkage. its the 2 step bracket with 2 bolt holes, stabilizer bolts to it 10 if you are intown, 5 if you drive here lol
various brackets and sensors removed from d15b7 automatic chassis and motor
bucket of bolts and nuts and small brackets
ARP flywheel bolts for non vtec b16 and b18 motors 15 OBO
ALL PICTURES are at request. my phon's usb port is being very VERY touchy and when it finally works, it takes over 20 minutes for one picture to load
until I can find a way to fix this issue, I am forced to do pictures by request only.
I apologize for this inconvenience
All parts are located in La Crosse, WI 54601. PM me for contact info. I am NOT shipping any of these parts or the motor
LIST NOT COMPLETED Im sure Ill find a few more things to throw up there
please bare with me folks, thanks
ODD PARTS
BUMP never got a hold of a camera. cellphone pictures by request, sorry. Im too busy running around trying to find a job instead of spending hours trying to get the pictures to upload correctly
if you are in lacrosse, wi and want to lend me a camera for a day, that would be awesome
Sory guys, been really busy with things and havent been able to get around to doing any pictures. if you see something you want, you can still pm me, until then I dont know when I can update this. thanks
-Matt
-Matt
Sorry, Ive been really busy dealing with a lot of personal issues and been having a hard time getting at the computer
pictures are finally loaded on my computer, I have yet to upload and post them
I will edit and update when I can.
I apologize in advance for the craptastic pictures, but they are the best I can do with my current cellphone.
current sales album
http://s244.photobucket.com/albums/g...rrent%20sales/
current sales album
read my 3rd to last line in my first post.
I cannot afford to ship any items. my paypal does not work as it needs a bank account and I owe money to the bank, hence why I am selling these items instead of simply keeping them for my next del sol.
sorry guys, no shipping
Id like to say 4-5 hours west of chicago, along the western/central part of wisconsin, mississippi river edge
Ill edit with a map in a few minutes or an hour
EDIT 327 miles, 5 hours, 14 minutes
http://maps.google.com/maps?hl=en&so...ed=0CAsQ8gEwAA
