Radiator fan Switch removal
Old Nov 2, 2009 | 04:27 PM
Lloyd Xmas's Avatar
Default Radiator fan Switch removal
What has people used to remove/unscrew the radiator fan switch from the housing? I tried my biggest pair of pliars, a pair of vice grips..the only thing I havent tried is channel locks which I dont have. Its pretty tight on there.
Old Nov 2, 2009 | 04:40 PM
mowermechanic's Avatar
Default Re: Radiator fan Switch removal
A small impact screwdriver? One that you hit with a small hammer?
Old Nov 2, 2009 | 04:49 PM
redbull-1's Avatar
A 24mm wrench.
Old Nov 2, 2009 | 04:51 PM
a1320addict's Avatar
A 15/16" will do you fine, dependent on what motor this is, you may have clearance issues getting the socket on flush due to the water bypass outlet. An adjustable is your friend, lol.
Old Nov 2, 2009 | 10:05 PM
bseriescrxsi's Avatar
if you use a vortex gearwrench socket it will go on with very little effort and you wont have to worry abouyt it not fitting over the sensor
Old Nov 3, 2009 | 05:51 AM
Lloyd Xmas's Avatar
Got it. Thanks for the tips.
chellerfl
Jul 13, 2016 07:43 AM
dman81
May 28, 2014 03:20 AM
FSRslug
Mar 16, 2011 07:59 AM
LukieLuc
Jun 9, 2007 09:06 PM
fast22civic22
May 31, 2007 09:34 AM
