1991 Accord ghost
Old Nov 2, 2009 | 04:01 PM
mowermechanic's Avatar
Default 1991 Accord ghost
On a 1991 Honda Accord EX automatic, is the CEL supposed to come on for 2 seconds for self-check? Or not on Hondas?
I was running a little seafoam down the pcv valve tube into the f22a4's intake. I shut it off for 5 minutes, started it up, and it popped a couple times, then no spark. I wasn't getting any CEL when i turned the ignition to the "on" position. I disconnected ECM and powered the CEL wire, and the light in the dash is good. So I swapped ECM's and still no CEL. I am getting power to the ECM, i'm just not sure which all wires are supposed to be hot to the ECM. It seems like the main relay is working (fuel pump primes), and i have power to the ignitor, and the coil tests out good. Any common problems with these?
(Yes I checked ALL panel fuses inside and in engine bay, don't know about fusable links though.) Thanks guys.
Old Nov 3, 2009 | 06:20 AM
Default Re: 1991 Accord ghost
bumpity bump bump?
Old Nov 3, 2009 | 12:36 PM
CarsAddict's Avatar
have you tried ringing the manufacture? they may be able top help you out.
KingJeremy2315
Dec 1, 2015 12:39 PM
Mr learns alot
Sep 28, 2014 08:35 AM
slel_Lee
Apr 28, 2013 03:09 PM
EJ1120
12
Apr 9, 2013 02:17 PM
TOR
Sep 24, 2007 09:06 AM
