00 honda civic lx wont start have b swap
i have a 2000 honda civic lx with a gsr swap it cranks but dont start i check if i have sparks and i do and then i also replace my fuel pump but still do the same thing i dont know really no what to check for
fuel pump turn on and i hear the main relay turning on and check all the fuse replace it check all my spark is all good and change too like 3 ecu still not turning but it crank like it wants to start anybody please help me
so timing could cause the car not to start up ?and i also disconnect the fuel line that goes to the fuel regulator and turn it to the on position and fuel shoot out fine but ill work on it tonight to see whats goin on
how do i check for that ??? all i did was unplug the line that goes on bottom of the fuel regulator and when i put it on the on position (WHEN ALL THE CLUSTER LIGHTS TURNS ON AND FUEL PUMP RUNNING AND MAIN RELAY CLICKING) fuel comes out of that line is that a good way of checking it?
I can't believe no one's asked this yet:
Has it run in this car before and stopped, or did you just swap it and can't get it started? What year is the engine? What year is the ECU? What ECU are you running? What OBD level is the car/ECU? The car should be OBD2b - Are you also using a 2b ECU, or something else with a jumper harness?
An OBD2b GSR engine with an OBD2b GSR P72 ECU will not start in a Civic without ECU mods.
