how to install aem tru time cam gear?
Old Nov 2, 2009 | 01:31 PM
sins's Avatar
Default how to install aem tru time cam gear?
I need help on how to install a aem tru time cam gear for a sohc vtec?
Old Nov 2, 2009 | 01:42 PM
90_EX_Civic's Avatar
Default Re: how to install aem tru time cam gear?
wow, for an '06 id thought you would know better.
a quick search in the faq and i got this,
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-complete-diy-how-timing-belt-water-pump-change-d16z6-lots-pics-649277/
it's basically how you would start it. the tricky part is deciding if you want to loosen the 14mm(i think) bolt while the belt is on or while the belt is off (harder if it's off unless you have the right tool). and you don't have to take the belt completely off. just enough to slip the belt off the cam sprocket.
Old Nov 5, 2009 | 12:45 PM
sins's Avatar
https://honda-tech.com/forums/showthread.php?t=649277
thanks for the info
redred1188
Jul 7, 2012 08:03 PM
boomersz
Feb 24, 2007 08:19 PM
sporkcrx
Sep 22, 2002 04:22 PM
95GS-R
Aug 14, 2002 01:42 PM
GSR -97
Dec 1, 2001 08:52 AM
