si/dx engine wiring harness
the Si engine harness has 3 connectors at the passenger side firewall connection - the DX harness has only 2 connectors
the Si harness has a round 8 wire connector (88 CRX Si has rectangular 6-wire) at the driver's side firewall connection - the DX harness has a round 14-wire connector
the Si harness has a round 7-wire connector at the distributor - the DX harness has a rectangular 5-wire connector
the Si harness has a rectangular green connector for the injector resistor box - the DX doesn't have this connector
the Si harness has 4 fuel injector connectors - the DX has 2 injector connectors
Si passenger side connectors:
DX passenger side connectors:
Si driver's side connectors:
Good info. Missd that one lil plug thanx
so instead of adding wires for mpfi swap
is it possible to put a crx si underdash harness in with the si engine harness?
im trying to right now..
but im not having much luck..
Thanks but i should have been more clear, i have an a6 swap ready to go in my 91 dx, and i just need to know what colors on the dx harness match with the si plug(s)
what is the 3rd little one for? trying to convert this harness to dx mpfi and obd1
