oem throttle body vs. aftermarket throttle body
need help with this,. im thinking of changing my throttle body dont know what to get, the oem or the after market.. im looking for 70mm size tb. does the 06-07 civic si throttle body got the 70 mm size?
you need to research some. Try google.
for help I'll tell you that 70mm on a bolt on car is too big. You can get a tsx throttle body which is slightly bigger or you can have that one bored. The stock is 60mm and cant be bored b/c the walls are to thin and it cracks.
Ive already said to much. GL
I think the TSX throttle body is 64mm...You see some gains in high RPMs but from what I have seen I am not convinced its a worth-while mod.
