b17, h23, GT35, HF manifold etc
Still have some stuff lying around, we cleaned up the shop and I want to get rid of these things...
H23A1 head, I have the missing parts (followers, camshafts, valve cover etc), here's a pic of the head. Pulled complete from the engine I'm using just for the bottom end. Also have the intake manifold and a stock H22A header modded to fit a 92-96 prelude (can be modded to fit anything with some quick cut and weld).
My B17A1 block. What you see is what you get, crank and rods are GONE, it's a bare block with the main caps and ARP main studs, near new water pump and modded "type-R" oil pump. I do also have the windage tray and tensioner not pictured, I guess pretty much everything but the oil pan, crank, rods and pistons.
older pics:
Also have these Skunk2 Prototype camshafts still, ran these in my B17 build, they are pretty large and probably not for your average street motor, 300/300, 13/13.
HF manifold for DIY turbo setups:
Garrett GT3071, T3 flanged with Ford 5-bolt discharge. My friend had this on his Audi and swapped it out after very little use for a 3076.
Best offer, also willing to make trades for H22A head and QuarterSport H2B kit.
*EDIT: the turbo is a 3071, I made a mistake when I initially listed it as a GT35*
older pics:
$950 for the turbo shipped, please note I edited the original post, I thought it was a 35 for some reason but its a 3071, it's my roommate's turbo from his Audi and I got confused, IIRC he has a spare 35R exhaust housing though. I'll throw the HF mani in for $20 if you get the turbo as well.
XES
Nov 24, 2005 07:07 AM
