up grade brakes
Old Nov 1, 2009 | 11:45 AM
Hectorzg1's Avatar
Icon6 up grade brakes
i wanna up grade my braking and keep it 4lug with 15s.
i read an article on honda tuning of a dc2. i noticed tha the brakes were up graded with itr calipers but kept the 15s and 4lug..
im woundering if the itr caliper can just bolt up to rs steering knuckle and done. .
Old Nov 1, 2009 | 11:57 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: up grade brakes
The steering knuckles are the same. You must machine or purchase 92-96 prelude VTEC rotors that have been redrilled to 4x100. The caliper also needs to be machined by 2mm.
How to: 11 inch brakes on 3rd gen - Honda-Tech
This is linked in the FAQ thread.
► ALL GEN Integra [FAQ] - DIY,Write ups, How to, etc
Old Nov 1, 2009 | 12:04 PM
SleeperGSR's Avatar
why do you want to upgrade your brakes? Usually just a good set of pads is enough.
Old Nov 1, 2009 | 03:40 PM
nsxtasy's Avatar
H-T Order of Merit
Yup, exactly. The easiest and least expensive way to get a big upgrade in your brakes is to get a more aggressive brake pad. Depending on how you're using your car, that may be all you need.
What, exactly, are you trying to accomplish? For example, if you want shorter stopping distances, in many cases your best move would be to get stickier tires. Brake pads can't reduce your stopping distances if your tires are the limiting factor in your braking, and they probably are, unless you're using really sticky tires.
Are you having any problems with your braking? For example, if your brakes are fading when they get hot, you may be boiling your brake fluid - in which case that may be caused by failing to change your fluid regularly. You can also get high-performance brake fluid which boils at a higher temperature, which can reduce problems with fade.
Are you using your car on the racetrack, or in autocrosses? Or just on the street? (There are specific brake pads for competition use that may help.)
Or do you just want to upgrade your brakes so you'll have bragging rights on the bench racing circuit?
Tell us why you think you want to upgrade your brakes, and what problems you are now having that you hope will be eliminated by doing so.
Old Nov 1, 2009 | 06:35 PM
Dcteg94's Avatar
^^Agree^^. Bigger brakes are not always the best option, unless you want them just to have them. There definatly more cost efficiant ways to solve a brake problem or reduce 60-0 stoping distances.
Old Nov 1, 2009 | 09:02 PM
Hectorzg1's Avatar
yeaaaa just to have them. .
naah its its just my going out car not my dd. over protected of her..
Old Nov 1, 2009 | 09:06 PM
Hectorzg1's Avatar
prob right just up grade pads and rotors. .
easy way out.. .
Old Nov 2, 2009 | 08:40 AM
nsxtasy's Avatar
H-T Order of Merit
Just do the pads. Don't even bother changing the rotors. They won't do anything for performance on a street car.
Old Nov 6, 2009 | 05:42 PM
JDMCIVICMAN1992's Avatar
+1. I'd recommend Hawk HPS as an upgrade over the OEM pads. I used the HPS+ in autox but they are a bit grabby for the street and need to be heated up a bit.
If you wish to have a firmer pedal feel consider going to stainless lines when it is time to replace your aging rubber OEM lines. It made a world of difference on my auto-x EG and had no downside to regular driving.
I may have some NIB pads/lines in my workshop if you are interested (shameless plug). Just send me a PM.
bobnbeck
Oct 25, 2017 05:29 PM
dc2r_j
Acura TSX
Apr 21, 2010 06:37 AM
LS stretch
Feb 13, 2009 08:57 AM
h23prelude
Aug 1, 2008 09:16 PM
crj_lll
Dec 26, 2005 05:22 PM
