mugen header corrosion
Old Nov 1, 2009 | 09:21 AM
tipe R's Avatar
Default mugen header corrosion
Sorry if this topic has been covered.
I have a Mugen 4-2-1 header that I bought used. I spent about 2 weeks polishing it and by the time I was done it looked new. After about 2 weeks of driving it started to look oxidized. Just wondering if any one knows any way to prevent oxidization on these headers. I used fine grit sand paper to polish it, starting from 1000-2000 grit. I'm not sure if that could have contributed somehow but any input would be great. I'll try to get some pics up.
Old Nov 1, 2009 | 09:29 AM
John M's Avatar
Default Re: mugen header corrosion
Send it off to jet hot and let them coat it inside and out.
it will still look the same after a year or too
Old Nov 1, 2009 | 09:34 AM
get RIGHT's Avatar
What John said.
Also make sure you never get fingerprints on a non coated header. The body oils burn off when it gets hot and that residue corrodes and turns to rust. Simple to fix but it is time consuming and annoying.
Old Nov 1, 2009 | 09:38 AM
tipe R's Avatar
is that ceramic coating?
Old Nov 1, 2009 | 05:25 PM
TiradoCC's Avatar
New User
Only way to prevent oxidation is to have it ceramic coated.
You didn't do anything wrong, they just start to change colors because of the amount of heat going thru the headers.
___
Carlos Tirado
TiradoCustomCoatings
EM1SiR85
10
Nov 27, 2008 10:11 PM
kidzoom206
Oct 31, 2003 01:31 AM
LostLude
Feb 9, 2003 08:14 AM
supergodzilla
May 16, 2001 07:50 AM
