Valve Stem Base Seal Question
Old Nov 1, 2009 | 08:00 AM
Atomic1's Avatar
Default Valve Stem Base Seal Question
I had a local shop put two new tirerack tires on rims I already had. They put new valve stems on. On both, if i push the valve stem to the side, I hear hissing out of the stem base. The shaft isn't cracked, but it is coming out of the seal.
None of my other tires do this... before I walk into the shop asking them to redo the mount I want to make sure this is a legit problem. I mean, it seems like they're not losing pressure otherwise.
Old Nov 1, 2009 | 08:12 AM
jdmwannabee's Avatar
Default Re: Valve Stem Base Seal Question
it is a problem.
sounds like they have a small crack.
i would have them replaced.
Old Nov 1, 2009 | 08:54 AM
Atomic1's Avatar
thanks
Man, this really pisses me off. Aside...Do any private shops do good work anymore? I do most of my own work, but it seems like whenever taking it to shops nowadays it's nothing but problems and multiple returns. Honest to god I cant even get my oil changed mid winter anymore without someone stripping out my oilpan or forgetting to put a washer back on.
Old Nov 4, 2009 | 08:24 AM
Gonzob16's Avatar
Take it to a Discount tire or something.
Old Nov 4, 2009 | 09:39 AM
nsxtasy's Avatar
H-T Order of Merit
When I've been away from home, I've had very good tire service at Wal-Mart.
mikzsan
Jan 23, 2013 02:28 PM
racerrck1
Aug 16, 2008 03:03 PM
loudsubz
Nov 24, 2007 11:27 AM
Maharajamd
Oct 18, 2007 04:33 PM
chjkingme
Dec 14, 2004 09:52 AM
