'95 Integra RS with JDM B18B will not run right unless I use a P06 ecu?
I recently replaced the B18C1 I was running in my 4/10 mile oval dirt track racecar ('95 Integra RS) for an OBD2 JDM B18B (VTEC engines were outlawed after I won a race). After installing the B18B things have not been right. The engine will run great at times, but it never seems to sound quite right at idle, and it sometimes acts as if it is running on 3 cylinders. I changed all of the following with new parts:
- NGK spark plugs
- OEM wires
- OEM cap
- OEM rotor
- fuel filter
- fuel pump is a Walbro 255 lph
I also checked the following:
- different distributor
- different P75 ecu
- cleaned all grounds
- checked and changed the TPS
In a last ditch effort I threw an automatic P06 I had laying around in. It had an interesting up and down idle, but it ran perfectly. My question is, what would make the engine run correctly with the P06, but not the P75? I am truly stumped, and I need all the extra power and rpm range I can get as this track is quite fast. Any help would be greatly appreciated. Thanks!
- NGK spark plugs
- OEM wires
- OEM cap
- OEM rotor
- fuel filter
- different P75 ecu
somedude1717
Jul 13, 2016 12:11 PM
weavertime1
Engine Management and Tuning
Nov 2, 2009 06:04 PM
