? ? ? Is a lil bit of wheel rub bad for ya? ? ?
Old Aug 30, 2002 | 03:04 PM
osbornsm's Avatar
New User
Default ? ? ? Is a lil bit of wheel rub bad for ya? ? ?
I just got my 17's and lowered 1.8. Lil bit of a rub there. Is that okay?
What's a good / cheap camber kit i can get to fix my whaked rear alignment?
Old Aug 30, 2002 | 03:17 PM
Reid's Avatar
Global Moderator
Default Re: ? ? ? Is a lil bit of wheel rub bad for ya? ? ? (osbornsm)
Wrong forum.
A little bit of rub is fine as long as you can live with the fact that the softer of the two parts rubbing will wear away until they no longer rub.
Get an Ingalls rear camber kit.
Your car is clearly too low for good handling, but that's not the point here.
Old Aug 30, 2002 | 04:36 PM
ZygSpeed's Avatar
Default Re: ? ? ? Is a lil bit of wheel rub bad for ya? ? ? (Reid)
Was it just the avatar?
I don't suppose that is a Porsche tractor, or a Lamborghini ...
Old Aug 30, 2002 | 06:37 PM
EPGONZALEZ's Avatar
Default Re: ? ? ? Is a lil bit of wheel rub bad for ya? ? ? (Zygspeed)
any type of rub is bad...its pretty close to tapping the brakes on that wheel only...
so things could get scary real quick
Old Aug 30, 2002 | 08:42 PM
NW94RS
Guest
Posts: n/a
Default Re: ? ? ? Is a lil bit of wheel rub bad for ya? ? ? (EPGONZALEZ)
just figure if you experience wheel rub on daily driving, now picture that with major body roll, get an ingallis (typo) camber kit wheel rub is not your FRIEND.
Old Aug 30, 2002 | 08:59 PM
norice's Avatar
You can get a 1/2 degree or so of positive camber in the rears with some washers.
Old Aug 31, 2002 | 12:54 AM
osbornsm's Avatar
New User
Default Re: ? ? ? Is a lil bit of wheel rub bad for ya? ? ? (norice)
All i can get is a 1/2 degree with the washers huh... i thought i was like 1ish ?
Old Aug 31, 2002 | 09:20 AM
norice's Avatar
Perhaps you are right - it has been so long since I did mine that I can't remember. I recall using two stainless steel washers on each of the two bolts on each side and getting about 1/2 degree.
chjkingme
11
Apr 14, 2013 03:44 PM
4serioferio
22
Mar 14, 2009 08:22 PM
zbra09
Suspension & Brakes
Oct 5, 2008 07:41 AM
dacaveman
Nov 29, 2003 03:18 PM
drvfast
Mar 17, 2003 02:21 PM
