89 crx si d15b2/y8 z6IM (wont stay on)
Old Nov 1, 2009 | 01:22 AM
UCNTCME's Avatar
Icon6 89 crx si d15b2/y8 z6IM (wont stay on)
So like the title says I have an 89 crx si with a mini-me swap in it. I finally got the car started today but it won't stay on. I turn it on and it revs to 2k then stay at 1.5k then just turns off, everytime. Just wondering what i should check or what it could be. Also before I forget when I push down on the gas It just turns off. WTF!$#%! is that? If you guys need more info let me know.
Pls help me out I need this car running asap to get to work and back. Really appreciate
your input. Thanx! Joe
Old Nov 1, 2009 | 02:44 AM
Jockobo's Avatar
Default Re: 89 crx si d15b2/y8 z6IM (wont stay on)
are the plugs for the tps and map sensor correct? their the same plug style so it can easily be swapped on accident.
Old Nov 1, 2009 | 09:46 AM
UCNTCME's Avatar
I believe they are one of them is coming from in the car out the firewall that one i plugged into the tps. the other one is coming from my harness and its plugged into my map sensor. that is correct right.
Old Nov 1, 2009 | 09:40 PM
UCNTCME's Avatar
Bump need help pls!
Old Nov 2, 2009 | 05:55 AM
Malgerus's Avatar
Throwing any codes?
Try switching the plugs. Maybe it's too early in the morning to think, but it sounds like you have them backwards. Can't hurt anyways. Did you switch the wires in the TPS when you did your conversion? Did you remove the TPS at all? If you did remove it, maybe you didn't reinstall it correctly.
jimmy o.
Jan 19, 2010 01:57 PM
RenX
Jun 18, 2009 07:17 AM
mugenwannabe
Dec 2, 2004 06:36 PM
RicedREX
Oct 14, 2004 01:52 PM
KinGClowN
Dec 24, 2003 05:26 PM
