B16 HEAD cheap
jdm sir2 b16a longblock.
complete head up to valve cover and manifold, complete block with everything still inside, blew headgasket and wasnt driven since. i got it thru a trade with my other motor and i SAW i run so no knocks or anything. Nothing is warped and none of the sleeves are scarred and i have the head off if serios buyers want to go check it.has a fizdana lightweight flywheel on it. coolant was mixing at higher rpm's in cylinder 2. all it will require to be running again will be a new headgasket and the head milled for good measure. EVRYTHING in the head and block is there and assembled already. Only thing done was the head was pulled off.
looking for 350.00 for it all. great for someone wanting a budget motor, or a head and great all motor pistons for lsvtec.
