Announcement: IB has valvetrain, coming soon, heres the specs:
Old Aug 30, 2002 | 02:27 PM
ImportReview
Guest
Posts: n/a
Default Announcement: IB has valvetrain, coming soon, heres the specs:
We have a dual spring similar to the toda that can handle up to 14 mm of cam lift. The pressures are as follows, installed @34 mm you have 70 LBS. on the seat and @ 10 mm of lift the open pressure is 185 LBS. so @ 13 mm of lift you should have around 210 Lbs open.
So its a stiffer spring geared for people that want to rev their motor 9,000 RPM + and who want to use larger cams, such as Toda, Skunk 2 or Crower.
The spring set, with Ti retainers will retail for: $425 and that includes the Titanium Retainers.
We needed to come out with our own valvetrain because we are finding that the future generation of Honda Import Enthusiasts will want to rev past 10,000 RPM.
So the valvetrain was born.
IB Spec valvetrain. Coming in weeks.
Jeff
Old Aug 30, 2002 | 02:47 PM
non-VTEC's Avatar
Default Re: Announcement: IB has valvetrain, coming soon, heres the specs: (ImportReview)
sounds good jeff..............any chance you could tell everyone who makes them for you?......just so everyone knows that there from a good reputable manufacturer.
Old Aug 30, 2002 | 03:01 PM
FSTASNTZ's Avatar
Default Re: Announcement: IB has valvetrain, coming soon, heres the specs: (non-VTEC)
Nice. You make it really hard for a guy to stick to his word and not build another motor...
Jason
ImportReview
Guest
Posts: n/a
I can't say, its a big name though. I will tell you that.
Alot of big name companies won't tell me where they make their stuff. I can see why now.
I pay alot of money, get a custom spec item made for me, its a way better deal in the long run.
Jeff
Old Aug 30, 2002 | 09:32 PM
TREVER's Avatar
do you have some with a Ti look finish. Will these make it ok to rev my 95mm stroke b16 over 9k.
Old Aug 30, 2002 | 09:51 PM
ARunto's Avatar
Default Re: Announcement: IB has valvetrain, coming soon, heres the specs: (TREVER)
will this have aftermarket keepers as well??
Old Aug 30, 2002 | 09:54 PM
GokuSSJ4's Avatar
Default Re: Announcement: IB has valvetrain, coming soon, heres the specs: (ARunto)
keepers are important does any one make any ?? especially if you are reving pass 9500rpms
Old Aug 30, 2002 | 10:23 PM
ImportReview
Guest
Posts: n/a
Default Re: Announcement: IB has valvetrain, coming soon, heres the specs: (Spoon1)
Ferrea makes keepers. I sell them.
I have keepers for the valvetrain also.
Jeff
Old Aug 30, 2002 | 10:42 PM
GokuSSJ4's Avatar
i know that ferrea sell's a lot of things but can you use the keepers with regular valvetrain since they make somethings to actiolly go with their valvetrain components
Old Aug 31, 2002 | 02:15 AM
ill phil's Avatar
Sounds pretty promising Jeff. Picking out my parts seems to be getting easier and easier Now all you need to do is get your own grinds for cams and you'll be set.
Brent
Old Aug 31, 2002 | 05:08 PM
ImportReview
Guest
Posts: n/a
Default Re: Announcement: IB has valvetrain, coming soon, heres the specs: (ill phil)
Thats what I was thinking Phil.
IB cams.
Problem with that is they are VERY expensive to mass produce. And I don't have that kind of capital.
I think it costs about 30k to start.
Jeff
Old Aug 31, 2002 | 05:41 PM
ill phil's Avatar
Damn! That is expensive. But hey ya never know down the line...... When are you expected to start selling the valvesprings and retainers?
Old Aug 31, 2002 | 07:28 PM
ImportReview
Guest
Posts: n/a
3-4 weeks probably
JDiMageDC2
Aug 13, 2010 04:56 AM
warwagon
10
Jan 28, 2005 10:03 AM
vti444
Jul 27, 2004 12:37 PM
acuraqc
Feb 12, 2004 07:31 PM
blwnb16a
Oct 27, 2003 12:50 PM
